Light glow
What was the best way to fix the glowing fingers? Measurement distance or something?
And yes the face is kinda dark :/ the preset of the Log house is not good enough.
    @Loony "What was the best way to fix the glowing fingers"
    The fingers aren't glowing (i.e. emitting their own light), they are transmitting light through the tissue. Your can see the effect in real life on fingers, ears, and noses in particular.
    Iray is a Physically Based Render engine. It simualte the behavior of light on materials including reflection, refraction, translucence, and transmision
    What you are seeing is a realistic depiction of the translucence of human flesh and transmission of light through same. The face is drak becuase your scene only has a light source behind the subject. That's pretty much the same thing you would get with a camera.
    If you don't want those effects, use 3DL.
  • LoonyLoony Posts: 1,817
    I added now light from the front, that changes it, win+win, did wanted to make her appeareance more visible.
