dzcloudtasknotifier.cpp errors?
ac_mr_blonde
I'm not sure what dzcloudtasknotifier is, but it's spamming my log with the following errors. Anyone know what this might be about?
2020-11-20 18:19:43.075 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: HTTP/1.1 400 Bad Request
2020-11-20 18:19:43.076 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: Date: Sat, 21 Nov 2020 00:19:44 GMT
2020-11-20 18:19:43.076 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: Server: Apache
2020-11-20 18:19:43.082 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: Vary: Accept-Encoding
2020-11-20 18:19:43.082 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: Content-Length: 226
2020-11-20 18:19:43.082 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: Connection: close
2020-11-20 18:19:43.087 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: Content-Type: text/html; charset=iso-8859-1
2020-11-20 18:19:43.088 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection:
2020-11-20 18:19:43.088 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
2020-11-20 18:19:43.131 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: <html><head>
2020-11-20 18:19:43.131 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: <title>400 Bad Request</title>
2020-11-20 18:19:43.131 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: </head><body>
2020-11-20 18:19:43.164 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: <h1>Bad Request</h1>
2020-11-20 18:19:43.164 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: <p>Your browser sent a request that this server could not understand.<br />
2020-11-20 18:19:43.164 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: </p>
2020-11-20 18:19:43.198 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: </body></html>
2020-11-20 18:19:43.198 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
This is a known issue, and it has been reported. I would suspect it's related to the store software change.
That's answered my question, many thanks
pete
I see this post is from last year. Has anyone ever bothered to fix this error or is there a work around so my DS does not keep crashing when trying to render image series? Where is this file located? I cannot seem to find it ? dzcloudtasknotifier.cpp
2021-10-25 10:13:39.319 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in contentGetByRelativePath: Unable to connect to the database, can not quote
2021-10-25 10:13:41.531 A valid PostgreSQL CMS connection could not be established. Several DAZ Studio features that require a valid PostgreSQL CMS connection, such as context aware content views and loading content installed using the Daz Connect service, will not be available. Check your network, anti-virus, and firewall settings for conflicts.
Note: I do not use SQL or DazConnect as both are usless in my network environment where 4 desktops needed to render multiple projects must connect to mapped drives so all assets are identical. This is how I have done it for years. Nothing changed.
I'm experiencing the same issue:
[WARNING] :: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://cdn.daz3d.com/file/dazcdn/p/76/5576/meta/5576_ff7c50_data.json) failed: HTTP response code said error
2022-12-05 11:27:00.719 [WARNING] :: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): TaskLoadProductDataWeb (5576) failed, url: https://cdn.daz3d.com/file/dazcdn/p/76/5576/meta/5576_ff7c50_data.json
2022-12-05 11:27:00.719 [WARNING] :: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(660): sync completed with errors, 1 items succeeded, 1 items failed.
