Objects missing on the timeline
Daz 4.14 is the gift that keeps on giving.
If I save a scene with some objects hidden, when I load it back those objects are gone from the timeline, I can't create/delete keyframes for them anymore.
In 4.12 I could unhide them and refresh the timeline and they would show up. 4.14 - they don't show up unless I resave the scene with them shown and reload it.
Anyone got a solution how to add those back without reloading?
  • I just tried a scene with three primitives, animated them all, hid two, saved as a scene adn reloaded. All retained their keys.
  • The keys are retained and are added via posing, but I can't see them in the timeline, can't add them manually/delete them.
    Ah, I thought you meant they were gone - yes, they are hidden for me and I can't find a way to bring them back within the UI - saving and reloading, with the niodes visible, does seem to do the trick.
  • VoidOVoidO Posts: 47
    SOLUTION:
    - Move your timeline to frame 0, the beggining of your animation.
    - Select, in the Scene pane, the object missing from the Timeline pane.
    - Press the "Delete" touch on your keyboard, which will delete your object alltogether.
    - Undo (CTRL-Z) which will undo the Delete by putting back the item at the bottom of your scene items, but doing so, will re-add it to the animation timeline.
  • VoidO said:
    SOLUTION:
    Same problem (now I'm using 4.21 and the bug was not fixed yet). Thank you for the solution!
  • LegacyAFLegacyAF Posts: 8
    There's a simple work around without deleting and undeleting your character.
    1) Create a new empty object in the scene at frame 0. The empty object is present now on your timeline.
    2) Move your missing objects into the empty object as child objects.
    3) Right click your timeline object area and 'Refresh'.
    4) The objects that were missing will now appear under the empty object you made and you may use them normally.
  • VoidO said:
    SOLUTION:
    Who would have thought thatlaugh, it's fixed thoughyes. For me, it happened when changing from Animated(Custom) to Current Frame. By the way, this trick can fix weird item rotation as well. Thank you
  • stitlownstitlown Posts: 324
    edited July 2024
    VoidO said:
    SOLUTION:
    Before you use this, note that there are things not kept in the undo buffer - such as ALL puppeteering - use with great caution as you only find what's missing down the track.  BTW, puppeteering missing from the undo buffer is a "design feature" notified to DAZ long ago, but has not yet made it into the "fix it" list.
    I can confirm that the safer "create an object, eg a group, reparent, REFRESH!" works.  You can even undo the reparent and the wayward item remains visible in the timeline.
    Post edited by stitlown on
  • alofaroalofaro Posts: 35
      Hope someone can help me, I have a problem that seems similar but if I understand correctly not identical, with 4.23. I loadead a scene where I have a timeline I used both for dForce simulation and to have four different scenes in one, by changing the position of the characters between different keyframes.
       Probably before I had saved it, I had hidden in one of the keyframes one of the characters to fine the position of the others. Result, at the start (and the end) of the timeline, every character is visible, when I move to the next keyframe, one character is not visible in the viewport, although in the "scene" tab it is marked as visible (and I checked, it is really marked as visible in the viewport).
        I tried both the method suggested (delete and restore, and creating an object, parenting and refreshing the timeline), but it seems it is still not working, when I move to the next keyframe, that character it is not visible. Any suggestion ?
    Good a place as any to ask this as I've not found it in the forums.
    The opposite - how do I get non-animated objects off my timeline?
    My timeline is cluttered with all sorts of object not being animated - and then animated objects keep disappearing off the time time.  I'd like to thin it out in the hope that actually animated objects appear there more readily / don't disappear.
    Cheers, Lx
  • Select the items/nodes then use Edit>Figure (or Object)>Clear Animation and choose the appropriate option.
