exporting a camera move
brownedave2brownedave2 Posts: 73
edited October 2020 in The Commons
Is there some way I can [export a camera move] do this?  I've tried exporting an FBX with a camera that does a simple move from one location to another.  Loading that FBX up in the other software, it had no animation information.  Just the initial camera placement was included.  I've subsequently tried simply placing two cameras at the start and end point of the camera move so I can set it up in the other software, but the tweening curve used by the other software seems to be slightly different than the one in Daz, or i've incorperated some slight misalignment due to manual positioning.  Had to manually set up the FOV, but that was not too difficult to eyeball.
Any help would be great.
Edited for Please put your question in the post body and the title - Daz 3D Forums
edit: found my problem.  Seems like it exports fine.  The software I am importing too is not reading it properly apparently.
  • You might try using a primitive as a proxy for the camera (use a Pose Preset to transfer the movement), then you can parent a camaera to the primitive in the destintation aplication.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,689
    Alembic abc files export camera movement
    I don't know if Sagan TheMysteryIsThePoint's free exporter does, I have not tested that
  • Thanks for your excellent suggestions, i'm going to look into both of these options.
    Also, sorry for my bizzare formating Richard.  Thanks for the fix.
