New Default UVs?
Tamuna
Is it possible to replace the default UVs of a figure with the custom imported ones? By replacing I mean I want the new UV set to be the only one, to remove the default set, and rename the new set as "Default UVs". Can this be done?
Post edited by Tamuna on
Well, you could hack the files to copy the data section from the new set into the old set - but of course that would then be overwritten by any product update.
Thanks for advice, I don't really know how to do that, lol. I was fiddling with a figure I made myself, so no threats from updates. Anyway, I found the way to do this is to update the entire geometry and that updates the UVs as well. Easy enough to do, even if not all that intuitive, so I'm not complaining.
