DIM beta install failed
TheKDTheKD Posts: 2,711
Today I decided to update windows, did a clean install. Installing all my graffix stuffs, was going well until I got to DS. Downloaded the beta with DIM, DIM just keeps failing the install. I installed the cms crap first, after the first fail. Here is the illuminating DIM log lol
2020-10-06 17:44:39.011 Installing: 12000-2 : DAZ Studio 4.12 (Win 64-bit) Public Build +BETA+
2020-10-06 17:44:39.639 Install Failed: DAZ Studio 4.12 (Win 64-bit) Public Build +BETA+
Post edited by TheKD on
  • fixmypcmikefixmypcmike Posts: 19,718
    What does the helper log say?
  • TheKDTheKD Posts: 2,711
    edited October 2020
    2020-10-06 18:34:44.280 Bad arguments to install product
    I also grabbed the general release, it seems to have stalled while installing the CMS, it hung there for more than 30 minutes, had to hit the cancel button.
    Closed DIM and tried gain, this ended up in the helper log
    2020-10-06 18:37:12.554 WARNING: ..\..\..\..\..\src\dzpostgresqlobjectdatabase.cpp(37): postgres create new db error: server closed the connection unexpectedly
        This probably means the server terminated abnormally
        before or while processing the request.
    2020-10-06 18:37:12.563 WARNING: ..\..\..\..\..\src\dzpostgresqlobjectdatabase.cpp(37): freeResources error: server closed the connection unexpectedly
    It might be Windows permissions blocking the CMS.  See if C:\Users\[yourname]\AppData\Roaming\DAZ 3D\cms exists and if there's anything in it, and if it allows you write access (set folder options to show system and hidden files and folders).
    edited October 2020
    cmscfg.json and a folder called "ContentCluster" filled with a bunch of stuff
    OK weird stuff. Decide to restart my PC before I ate supper, came back. Now both installed fine. Guess it was just winblows being winblows. Thanks for the time man lol....
    Does a standard user have write access?
