ISO Long Hair with a Crazy Amount of Movement Morphs [Solved]
3Diva
I'm needing a long hair with a nearly excessive amount of movement morphs. The project I'm working on requires a HUGE array of action scenes in which the hair will have to be able to move in just about every way imaginable (except upside down, it doesn't need to be able to do that - but it does need to be able to move in a large variety of ways). I don't have a lot of time to set up each scene so I can't really use dForce hair as the sim and setup time is too extensive to use dForce hair for this particular project.
The style needs to be long (at least past the shoulders) straight-ish (it can be wavy but not curly), and no bangs. It doesn't matter what generation it's for as I can always parent it to the figure's head if it's for a different generation.
If you guys know of any hairs with a style like that that also comes with a massive amount of movement morphs, I'm all ears! :) I could do my own morphs for the hair but that can be quite time-consuming, so I'm hoping to find one that works for my needs without a lot of additional work needed. I also could spend hours combing through the store looking, but I'm hoping to avoid that headache (and sometimes a hair will list a lot of morphs but the morphs hardly move the hair at all) - so hopefully you guys have experience with a hair model or two that you find has a lot of great movement options that would work for what I need. :)
Hey 3Diva! Janet Hair can be made to reach past the shoulders, and it has several pieces with 3 movements each. If you double it up, you can get even more movement. It is a great hair for action scenes since you can get almost any movement you want. Here are the pieces and movements:
lBack01-Bend, lBack01-Side-Side, lBack01-Twist
lBack02-Bend, lBack02-Side-Side, lBack02-Twist
lBack03-Bend, lBack03-Side-Side, lBack03-Twist
lBack04-Bend, lBack04-Side-Side, lBack04-Twist
lSide01-Bend, lSide01-Side-Side, lSide01-Twist
lSide02-Bend, lSide02-Side-Side, lSide02-Twist
lSide03-Bend, lSide03-Side-Side, lSide03-Twist
lSide04-Bend, lSide04-Side-Side, lSide04-Twist
lSide05-Bend, lSide05-Side-Side, lSide05-Twist
lSide06-Bend, lSide06-Side-Side, lSide06-Twist
lSide07-Bend, lSide07-Side-Side, lSide07-Twist
lSide08-Bend, lSide08-Side-Side, lSide08-Twist
rBack01-Bend, rBack01-Side-Side, rBack01-Twist
rBack02-Bend, rBack02-Side-Side, rBack02-Twist
rBack03-Bend, rBack03-Side-Side, rBack03-Twist
rBack04-Bend, rBack04-Side-Side, rBack04-Twist
rSide01-Bend, rSide01-Side-Side, rSide01-Twist
rSide02-Bend, rSide02-Side-Side, rSide02-Twist
rSide03-Bend, rSide03-Side-Side, rSide03-Twist
rSide04-Bend, rSide04-Side-Side, rSide04-Twist
rSide05-Bend, rSide05-Side-Side, rSide05-Twist
rSide06-Bend, rSide06-Side-Side, rSide06-Twist
rSide07-Bend, rSide07-Side-Side, rSide07-Twist
rSide08-Bend, rSide08-Side-Side, rSide08-Twist
That sums up just about every OOT hair I have.
Thanks, xyer0! I think I need something a bit longer, though. I didn't get as many suggestions as I was hoping for so I did some digging and I'm thinking of going with this one: https://www.daz3d.com/wild-wind-hair-for-genesis-8-females
It comes with over 100 movement and wind morphs plus is rigged with 13 bones. I'll experiment and see if the morphs move it enough for my needs. Unless the morphs don't "do much", in which case, this one might work: https://www.daz3d.com/super-sleeky-hair-for-genesis-3-female-s-and-genesis-3-male-s-and-oot-hairblending-2-0 (It says it comes with 193 morph dials! Whoa!)
I THINK one of those should work.
Thank you for the suggestion, it made me look at OOT's catalogue here to see if there was something that might work. The Super Sleeky one might be the way to go. I'll have to test both that one and the Wild Wind hair out. :) Between the two, I'm willing to bet one of them will do the trick! *crosses fingers*
Thanks again for the suggestion! :)
PhilW's https://www.daz3d.com/dforce-longdrape-hair-for-genesis-3-and-8-females
Although a Strand based hair, the lenght can be adjusted easily and it simulates very, very quickly. When I rendered in Iray, I used it whenever I needed a long hair
https://www.daz3d.com/olenna-hair-for-genesis-3-female-s
The tails have bones in them; actually I love AprilYSH hairs because as far as I can recall, all have bones in them - but its possible a couple dont.
