error
I got this error message when loading g8
zip
zip
DAZStudio_error_report_200927-173704.zip
109K
  • That looks to be an issue with the Intel GPU driver, do you actually have an Intel GPU on your CPU? If you do, and if you also have a stand-alone GPU (e.g. nVidia or AMD) then make sure DS is set to use the latter (in the GPU's Control Panel applet, usually available through a right-click on the desktop).
  • I have Intel hd graphic on my desktop. can I make it accept daz or do I need a new graphic card?
    Is that all you have? It may be worth looking to see if there are newer drivers, if so.
  • I checked and it says I already have the best driver installed. but just remembered something. my monitor is hooked to the desktop with hdmi cable does that matter?
  • LeanaLeana Posts: 13,696
    Where did you check, on Intel's site? Drivers provided by Microsoft update are not the ones you should use.
    For the record, I have an intel card on my laptop and DS does work (of course, it won't use the GPU to render)
