render missing textures (3delight message #3)
MaslafapMaslafap Posts: 5
I have DAZ studio 4.6 pro and when I render the log file shows me this list of errors:
Rendering in 3Delight
Compiling Shaders - 0/1
Compiling Shaders - 1/1
Rendering image
Rendering...
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d15_M4JeremyRRFaceB1.tdl' not found (in shader 'omnifreaker/displacement/omDispStandard' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d14_M4JeremyRRFaceM1.tdl' not found (in shader 'omnifreaker/surface/omHumanSurface' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d36_RyJesse_faceBU.tdl' not found (in shader 'omnifreaker/displacement/omDispStandard' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d7_M4JeremyRREyesTr.tdl' not found (in shader 'omnifreaker/surface/omHumanSurface' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d3_M4JeremyRRLimbsB.tdl' not found (in shader 'omnifreaker/displacement/omDispStandard' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d12_M4JeremyRRTorsoB_NG.tdl' not found (in shader 'omnifreaker/displacement/omDispStandard' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d51_RyJesse_lashesDis.tdl' not found (in shader 'dzdisplace' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d46_RyJesse_correfl.tdl' not found (in shader 'omnifreaker/surface/omHumanSurface' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d39_RyJesse_torsoBU.tdl' not found (in shader 'omnifreaker/displacement/omDispStandard' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d16_M4JeremyRRFaceS1.tdl' not found (in shader 'omnifreaker/surface/omHumanSurface' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d11_M4JeremyRRTorsoM_NG.tdl' not found (in shader 'omnifreaker/surface/omHumanSurface' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d8_M4JeremyRREyesB.tdl' not found (in shader 'omnifreaker/displacement/omDispStandard' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d40_RyJesse_torsoS.tdl' not found (in shader 'omnifreaker/surface/omHumanSurface' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d47_RyJesse_refl.tdl' not found (in shader 'omnifreaker/surface/omHumanSurface' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d49_RyJesse_eyesBU.tdl' not found (in shader 'omnifreaker/displacement/omDispStandard' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d2_M4JeremyRRLimbsM.tdl' not found (in shader 'omnifreaker/surface/omHumanSurface' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d4_M4JeremyRRLimbsS.tdl' not found (in shader 'omnifreaker/surface/omHumanSurface' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d43_RyJesse_limbsS.tdl' not found (in shader 'omnifreaker/surface/omHumanSurface' on object '')
3Delight message #3 (Severity 2): T2040: 'C:/Users/??????????/AppData/Roaming/DAZ 3D/Studio4/temp/d17_sKid4BasicBrief01.tdl' not found (in shader 'dzplastic' on object '')
This happed after transfering all my DAZ3D files from my old PC to the new.
Please can anyone tell me a solution for this?
  • Richard HaseltineRichard Haseltine Posts: 111,984
    Does the user name, which you've replaced with ?s, have any non-standard (for the US) characters in it? It appears that either TDLMake is failing to create the mip-maps used by 3Delight from the raw images or 3Delight is failing to read them, so something (user rights or the form of the path) interfering with access seems likely as a cause. Along the same lines, what security software are you using?
  • MaslafapMaslafap Posts: 5
    First of all thanks for the reply! I will start from the beggining. I transfered my DAZ and IM first at the exact same place from my old PC, (except the file which is located at: C/Users/AppData/DAZ 3D/Studio4) Then i went to DAZ 3D site and re downloaded IM and DAZ3D with all my purchased products of course. After downloading,installing e.t.c. I loaded a scene from my old PC which was exctrated to my new and I tryed to render it. The result was... black and white skins and missing textures from objects! I went to the folder which said me that the things were not found and I saw that the folder C:/Users/?????????? <- was something with weird letters, if you inderstand what I mean... So I deleted the file and tryied to reinstall the program because I thought there was a glich in installation.So I re-installed it. The thing is that DAZ did't replaced the deleted folder with a new. So I deleted all the folders with the name DAZ3D and DAZ from my computer and then I uninstalled IM and started all over again. But the problem remains... I don't know If I answered you all your questions but can you give me a way to fix this? I have spent some money on this and I don't want to lose them =(...</p>
    BTW I'm using Avast
    If your user name has weird letters that may well be the cause of the problem. Try going to Edit>Preferences in DAZ Studio and click the ... button next to the name of the folder under temporary files, then pick a folder somewhere safe (C:\Temp\DAZStuff perhaps), restart DS and try rendering.
    edited July 2014
    OMG... it works! Thank you so much, I don't know what to say! Thank you again :lol: So to avoid this happening again what do I have to do? Go to prefs and change my name from there?
    Post edited by Maslafap on
    The username is from your Windows profile, but DS will rmember the setting you just made so, as long as the files are OK where they are (if your C: drive is an SSD you may want them on another device) you should be OK from now on.
    well ok then :-)
