claustrum
I think the files of Claustrum lack an OBJ. file in the download of IM00018990-03_ClaustrumPs
clau_sq_mid.obj and clau_sq_steps.obj are just 1 kb and 22 kb each..... that means its an empty file
  • Richard HaseltineRichard Haseltine Posts: 111,992
    Not if it's a low polygon item - have you tried loading them, or are you just looking at the file size?
  • FirstBastionFirstBastion Posts: 8,089
    edited July 2014
    I just had a look, and they are simple .obj models hence the small size, but compared to the massively complex ivy they are what you would expect. The "step" is a two step platform, and the "mid" is a floor plane.
  • edited December 1969
    It isn't those two OBJ.files that's the problem I see
    the problem is that files are missing
    figureResFile :Runtime:Geometries:RHS:BRC-Cloisters:rhscloisters_backwall.obj
    and the rest of the CR.files of which the OBJ is directed to RHS:BRC-Cloister don't show up when loaded
    I did find these item in RHS:BRC-Cloist so I copied and pasted that file and renamed is BRC-Cloister.
    rebooted and still nothing showed up.
    As Claustrum is a texture set for the Cloister it will not contain the obj files for the original set, the CR2 will reference those obj files in the path for the CR2, at least this is how it works in Poser.
    reinstalling, rebooting, reloading
    and again in that order
    and the files showed up at last.
    problem solved.
    thank you
