Outfit problem
Hi.
I installed this outfit: https://www.daz3d.com/sugar-for-v4-outfit
but when I try to equip it on V4  nothing happens. Can anyone help me?
  • LeanaLeana Posts: 13,671
    Which files are you trying to load? Sounds to me you may be using a material file rather than the actual items.
    I'm assuming that's the outfit but when I click to apply it on V4 nothing shows up. I have no problem with other V4 outfits , just this one.
    1004 x 700 - 159K
    edited September 2020
    That thumbnail definitely looks like a material pose from a texture add-on. You need to load the actual clothes, from the figures library.
    Post edited by Leana on
    Where can I find them? I searched everywhere but I can only find that. And this is all that I have in that location
    Dusk folder is missing.
    979 x 506 - 118K
  • MelanieLMelanieL Posts: 7,895
    They should be in Poser Formats - Figures - SugarV4 - are you definitely looking under Poser Formats in Content Library?
    ETA: How did you install? I don't see why anything for V4 would be installed into a "Dusk" folder.
    Post edited by MelanieL on
    "Dusk" is not the folder for the product, that's the name of an add-on (this one I suppose).
    The folder to load the base outfit is "SugarV4" in Figures library. Once you've loaded the outfit you can apply the Dusk textures to it.
    436 x 833 - 176K
    Hello my outfit does not appear there. I have Sugar for V4 - Outfit This is the base product?
    Yes, this is the base product. I reinstalled it in a test directory to take that screenshot so that it is in the default location, so it should definitely be there.
    How can I install it in a test directory?
    I installed it manually: I unziped the product zip to a temp folder on my PC, then moved the runtime directory from the temp folder into a test folder listed as a content drectory in DS preferences.
    I installed the full bundle again and now it's working perfectly.
