Setting Camera Frame Width from script
Hi there,
I have a script that instantiate a new camera , position it and sets up the focal length and frameWidth( see exmple below)
cam.focalLength=20.78461;cam.frameWidth=24;The focalLength works fine, but the frameWidth isn't getting set.... after digging more into the docs I see that frameWidth is a read only attribute which explains why I can't set it. However, I assume there is another way around it just can't find any function that can do that.
Hopefully someone here knows the answer to that.
Thank you.
You can use the getFrameWidthChannel() method on the DzBasicCamera object then set the value:
I just saw this.
Yes, that worked perfectly.
Thank you so much.
