Adding a quick backdrop to a render
Jayne Wilson
I asked this question recently, in response to another thread. Unfortunately I can't find that thread now to see if anyone responded. I apologize in advance for the repeat question.
I just upgraded to a new iMac on Catalina, not sure if that has anything to do with the issue or not.
Before, if I wanted to add a backdrop I would select Backdrop from the drop down menu in the Environment pane, then choose browse to select the image I want to use. However, when I do that now, I can see all the files but they are all greyed out, and I can't select them.
Am I missing a step?
Which version of Daz Studio is this? Help>About Daz Studio
Sorry - should have mentioned that. 4.12.0.86
There are fixes for at least some of the Catalina issues in the newer, current version of DS. However, be aware - if you do animations - that scenes are dropping keyframes, saving a pose/shaping preset seems to be the only current workaround.
OK thanks - thought I had the latest version. I'll check and see if I do.
I don't do animations, so that won't be an issue :-)
That's what it was. I downloaded an update and all is good now.
