Master Control
Does anyone know of a master control setting, technique or product that allows you to control multiple scene/character settings in tandem.
Example - I have several clothing items on a character with mesh smoothing set to on. Everytime I try and pose a lag or hand, the smoothing modifier kicks in and slows the posing to a crawl. I can go to each clothing item and turn that option off - but it would be great to have a master switch to turn them all on/off at the same time.
Same with cloth simulations - have to keep freezing/un-freezing numerous items till I get the pose annd scene right - a master switch to turn on/off simulation freeze would be great - turn them on/off selectively even better.
Going to each individual item, drilling down to the parameter setting, making changes - then back again, gets old really fast.
I thought I saw a script/plugin for simulation settings talked about in another discussion - but can't find it now.
Any suggestions?
Thanks
The simulation settings thing you mentioned was probably the product by manfriday, which I believe also lets you turn smoothing on and off (provided it is also dforce)
https://www.daz3d.com/dforce-companion
I thinks that's it !!!
Would save a ton of time!
Thanks.
