Save genesis as .obj ?
flashbackflashback Posts: 0
I have a scene idea that requires a large number of genesis and gen4 characters. Most will be in the exact same pose so I thought to save them as .obj to save memory.
In DS4pro (not 4.5) how do I go about doing this? What settings etc to create the most economical obj for import?
Any help is greatly appreciated.
  • adamr001adamr001 Posts: 1,322
    Can you use the same texture on each? If so, you should instance them.
    Select Genesis and then
    Create > New > Node Instances
    I've got 11 textured, identical genesis in my scene and it's only using 450mb of RAM.
  • JaderailJaderail Posts: 0
    Not sure how it's done in DS4Pro Flashback. Only 4.5 has instances Adamr001, how can we do the same in DS4Pro?
    Oh right sorry, I saw 4.5 and went straight to instancing...
    In 4Pro, you'll have to export them to wave front object, making sure to use base resolution.
  • flashbackflashback Posts: 0
    base resolution?
    488 x 547 - 160K
    It's an option on the parameters for Genesis:
    694 x 507 - 38K
    Ah, thank you!
    Yes mucho thanko!
    If there's a reason to move to 4.5 it's instancing though, I'm telling ya, that's where it's at! ;)
    Give me Reality in 4.5 and it's on! The only plugin I must have, just have to have it.
    Heh, yeah, it'll be interesting to see what happens to instanced geometry when exported to Lux. ^_^
    Hmm... Very good point. Never crossed my mind untill you pointed it out.
    Still having problems, the textures are not saving properly. Going to have to dig into this. >:(
  • BejaymacBejaymac Posts: 2,019
    The material library (.mtl) that goes with the .obj is very basic, so if your using any fancy shaders (HSS, USS etc) then that info wont be saved in the .mtl
