Render Problem: Black
Earlier today on DAZ3D, I rendered a figure on a 3Delight which came out black. And then I tried rendering this gray shape using the same engine, also came out black. There must be something wrong with the render engine.
Is there a way to fix this rendering?
2146 x 1538 - 45K
Do you have a light sources? Is your surface using a 3DL compatible shader? is the object's shader set to all black/diffuse/no reflection? Are DAZ's render settings set to render the scene, or sun only, or another setting? Many things to check here.
