Hagar figure issue.
Hi,
I've just purchased the newly released 'Hagar for G8F' figure and on attached file you can see what I'm getting.
This only happends with Hagar figure. I've tried applying Hagar body and head to G8 base female and that worked fine. It's when I loaded the MAT the thing occured again.
It is visible only in Iray.
Anyone else has got this issue?
Please put some clothes on the figure - such as the Basic Wear from Starter Essentials.
It looks as if there is a displacement map assigned to the legs, or - if everything has displacement - as if the maximum value on the legs is much too large. You can check the Surfaces pane and probably fix the issue yourself, but please reprot it to Daz too https://www.daz3d.com/help/help-contact-us
You might want to check out this thread, as well.
https://www.daz3d.com/forums/discussion/421721/anyone-done-any-renders-of-hagar#latest
Thank you!
