Daz4.5 rendering
VitachickVitachick Posts: 135
Is there anyway, or is it in the works to see the rendering done in front of you? Choice render separate window or render to file. But then
unless you exit and re-open the image you can't see the rendered in the window. Doesn't make sense to me. Daz3 had it..You would just watch it render and poof it was done and you saw the finished product.
  • JaderailJaderail Posts: 0
    Render to New Window should pop to the front unless you have changed the way your System handles new windows. It does for me. That's with DS4Pro, I've not tried DS4.5 yet.
  • VitachickVitachick Posts: 135
    But once you close the render window you still see the window that wasn't rendered. on the screen with no changes made.
    Ever use Daz3? You will see what I mean..
    OH! That type of rendering. DS4 moved to the new way to Speed up the Render engine or something along those lines. I never read the 3Dlight Render engine stuff so I'm not sure why but it was done for a reason.
    Guess that is the way it is and going tol stay. Don't like it though.
    So you want to render int he Viewport instead of in a New Window?
    Yes so I can see the changes..
  • BejaymacBejaymac Posts: 2,008
    Try using the spot render tool, it allows you to render a user defined area of the viewport, that way you can check for any changes/issues without having to render the whole scene.
    Good idea!!!
    Thank you :)
