Spotrender crashes
Hi,
anyone can read the code and tell my why my Spotrender crashes? I made a ~2 Hour render and wanna "clean" parts via spotrender, but it crashes :(
2020-06-29 00:53:48.269 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 386 textures, 84 lambdas (38 unique)2020-06-29 00:53:48.279 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (4 light sources with 3370 triangles, 1 instance) took 0.000s2020-06-29 00:53:48.279 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.2020-06-29 00:53:50.083 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.2020-06-29 00:53:50.085 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.2020-06-29 00:53:50.085 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.2020-06-29 00:53:50.085 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.2020-06-29 00:53:50.085 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.2020-06-29 00:53:50.085 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.2020-06-29 00:53:50.090 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.2020-06-29 00:53:50.102 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer2020-06-29 00:53:50.116 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled2020-06-29 00:53:50.116 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.2020-06-29 00:53:50.151 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):2020-06-29 00:53:50.151 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : 	CUDA device 0 (GeForce RTX 2070 SUPER)2020-06-29 00:53:50.151 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...2020-06-29 00:53:50.151 Iray [VERBOSE] - IRAY:RENDER ::   1.9   IRAY   rend progr: CUDA device 0 (GeForce RTX 2070 SUPER): Processing scene...2020-06-29 00:53:50.423 Iray [INFO] - IRAY:RENDER ::   1.5   IRAY   rend info : Using OptiX version 6.1.22020-06-29 00:53:50.428 Iray [VERBOSE] - IRAY:RENDER ::   1.5   IRAY   rend stat : Geometry memory consumption: 1.63449 GiB (device 0), 0 B (host)2020-06-29 00:53:50.449 Iray [INFO] - IRAY:RENDER ::   1.5   IRAY   rend info : Initializing OptiX for CUDA device 02020-06-29 00:54:08.282 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: Unable to allocate 67108864 bytes from 2834303385 bytes of available device memory2020-06-29 00:54:08.290 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.9   IRAY   rend error: CUDA device 0 (GeForce RTX 2070 SUPER): Scene setup failed2020-06-29 00:54:08.315 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.9   IRAY   rend error: CUDA device 0 (GeForce RTX 2070 SUPER): Device failed while rendering2020-06-29 00:54:08.317 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.9   IRAY   rend warn : All available GPUs failed.2020-06-29 00:54:08.319 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.9   IRAY   rend warn : No devices activated. Enabling CPU fallback.2020-06-29 00:54:08.330 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.9   IRAY   rend error: All workers failed: aborting render2020-06-29 00:54:08.352 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 12 cores for rendering2020-06-29 00:54:08.353 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):2020-06-29 00:54:08.353 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : 	CPU2020-06-29 00:54:08.353 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...2020-06-29 00:54:08.366 Iray [INFO] - IRAY:RENDER ::   1.5   IRAY   rend info : Using Embree 2.8.02020-06-29 00:54:08.366 Iray [INFO] - IRAY:RENDER ::   1.5   IRAY   rend info : Initializing Embree2020-06-29 00:54:08.376 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.9   IRAY   rend error: CPU: Scene setup failed2020-06-29 00:54:08.376 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.9   IRAY   rend error: CPU: Device failed while rendering2020-06-29 00:54:08.381 Iray [VERBOSE] - IRAY:RENDER ::   1.9   IRAY   rend progr: CPU: Processing scene...2020-06-29 00:54:08.381 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.9   IRAY   rend error: All workers failed: aborting render2020-06-29 00:54:08.390 Iray Render error: Internal rendering error.2020-06-29 00:54:08.895 Saved image: C:\Users\Loony\AppData\Roaming\DAZ 3D\Studio4\temp\d3.png2020-06-29 00:54:08.983 Loaded image d3.png2020-06-29 00:54:09.040 Finished Rendering2020-06-29 00:54:50.491 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:2020-06-29 00:54:50.491 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: 	 0 iterations, 0.018s init, 0.005s render
I restarted daz3d already but ... doesnt helped.
I will now also try a PC restart, maybe someone can help
  • zombietaggerungzombietaggerung Posts: 3,943
    You've run out of Video Card RAM and it's dropping to CPU. I'd close and re-open DS and the scene to clear your video card.
  • LoonyLoony Posts: 1,817
    I did restarted daz3d that didnt helped, I restarted now my PC.
    And... no idea why, the scene worked now and holy Molly, it did take 31,2GB ram O_O.... even if I used on most textures Base res and not high ress....
    But my PC need anyway really a new install of win10 :/ I try to avoid it as long as possible :/ but the system runs not smooth...
    Thread solved, rebooting the system helps.
    get the problem now again ;( even restarting windows doesnt help, I get a 0iterations result. BUT I can render the FULL scene, what is going on ;(
    I hate it...
    edited June 2020
    It started the spotrender now but...
    warn : The 'iray_optix_prime' scene option is no longer supported.2020-06-30 19:14:54.879 Iray [VERBOSE] - IRAY:RENDER ::   1.0   IRAY   rend progr: 1.51% of image converged2020-06-30 19:14:54.898 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00172 iterations after 254.556s.2020-06-30 19:14:54.925 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.2020-06-30 19:15:19.744 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00191 iterations after 279.402s.2020-06-30 19:15:19.763 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.2020-06-30 19:15:46.757 Iray [VERBOSE] - IRAY:RENDER ::   1.0   IRAY   rend progr: 5.99% of image converged2020-06-30 19:15:46.775 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00212 iterations after 306.433s.2020-06-30 19:15:46.795 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.2020-06-30 19:16:16.537 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00235 iterations after 336.195s.2020-06-30 19:16:16.560 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - API:DATABASE ::   1.0   API    db   warn : Transaction is released without being committed or aborted. Automatically aborting.2020-06-30 19:16:17.812 Iray [VERBOSE] - IRAY:RENDER ::   1.0   IRAY   rend progr: Transaction closed, stopping renderer.2020-06-30 19:16:18.369 Error during rendering
    I have no idea what that Warnings are, my Graphic driver is fresh new installed (again!) windows got restarted too...
    I also got last Month a new graphiccard.
    So... maybe I really have to reinstall windows? :(
    I tested now a different scene, that worked, so I assume for some reason can my Studio not handle my scene... it crashes after a while :(
    Just 2 People in a little bathroom.
    Post edited by Loony on
  • Richard HaseltineRichard Haseltine Posts: 111,429
    Which version of DS is this (Help>About Daz Studio)?
    edited June 2020
    My Daz version: 4.12.0.86 (yes I am not on the newest-unstable Version)
    I was able to render it with the scene kinda hidden... had to adjust the peoples light a little big.
    Still confused, my RTX2070 Super with 8GB ram and my 32GB ram should be enough but it seems like not :(
    The Ram does go close to 32GB.
    Thats really a lot, 7Millions...
    I assume its that hair. it does also cause the 3D chip to go crazy if I rotate or anything, I have to hide it when I wanna work.
    Atleast the FPS dropps hard if I rotate around :)
    I thought it wasn't the current version from the message about OptiX Prime.
    nope not the newest, cuz I saw too much bug reports, I am happy I can use my current version :< (I am afraid I cant use it anymore when I reinstall windows 10 ... )
