Missing textures when exporting Obj
Hello there,
I hope this message finds you all well and safe.
The textures of my models are missing when I export them in OBJ format.
The same files come with textures when exported as FBX format.
How can I export my models as OBJ with textures?
Thank you,
_Ken
    KN said:
    Hello there,
    Thank you,
    _Ken
    Did you check off the box to collect maps?
  • AscaniaAscania Posts: 1,857
    Are they actually missing or is this just the usual issue with the textures not properly applying on import?
  • Does the .mtl file have exactly the same name, in the same directory?
    Did you save the .obj on a different computer with a different directory structure, so all the paths in the .mtl are wrong? If so, you can just fix them with any text editor.
  • KNKN Posts: 55
    Hello everyone,
    Thank you for your replies.
    In the Write Surfaces setting, I had "Original" selected.  I changed to "Collect" and the models were correctly exported with textures.
    Have a great week!  :-)
