NVIDIA Iray not using GPU
I know there have been plenty of these threads, but none of the ones that I have found seem to cover my specific issues. Whenever I try to switch the render settings to use the GPU, it doesn't work. If I am just doing the NVIDIA Iray preview render, the figure will turn stark white, the bottom left will day "Preparing scene..." and the status bar on the bottom right will continue to over and over again. If I am trying to do a full render, the render will start, immediately stop, and act like it finished by letting me save the file. Neither of these actions crash the program.
Here are my specs:
AMD Ryzen 5 3600 3.6 GHz 6-Core Processor
Corsair Hydro Series™ H100i Extreme Performance CPU Cooler with Thermaltake Riing Plus 12 RGB Tt Premium Edition 120mm Software Enabled Case/Radiator Fan
ASUS Prime X470-Pro AM4 AMD X470 SATA 6Gb/s USB 3.1 HDMI ATX AMD Motherboard
Corsair VENGEANCE LPX 16GB  DDR4 DRAM-3000MHz
SAMSUNG 970 EVO M.2 2280 250GB PCIe Gen3 SSD
Seagate Barracuda  2TB SATA 6.0Gb/s 3.5" Hard Drive
NVIDIA GIGABYTE GeForce GTX 1060 Revolution 2.0 6GB Gaming Graphics Card
Phanteks Eclipse P300 ATX Mid Tower Computer Case
EVGA SuperNOVA 750 G3 750W 80 Plus Gold Modular Power Supply
Microsoft Windows 10 Home
Corsair Glaive RGB Gaming Mouse
Corsair K55 RGB Gaming Keyboard
Dell 27" 60hz 1080p Monitor
  • Richard HaseltineRichard Haseltine Posts: 111,426
    A 6GB isn't massive, but ti should cope with at least simpel scenes. What driver version are you using - right-click the desktop>nVidia Control Panel and look for the number in the coloured box just above the GeForce GTX 1060 line.
  • paule.20paule.20 Posts: 0
    I had the same issue. I updated the NVIDIA driver to the latest version and it worked.
  • What driver version are you using - right-click the desktop>nVidia Control Panel and look for the number in the coloured box just above the GeForce GTX 1060 line.
    Version: 432.00. 451.48 is available, so I am going to upgrade to that.
    Thanks! I'll try that.
