Hello I do not know if this problem has already been seen but no matter what files I install (hair, clothes ...) I put them all in the same folder, Daz Studio gives me an error message "Error Opening Files" I may download absolutely anything I'll always have this message.
Which files a you trying to open, and what is the actual error message? (You should be able to see it in the log file)
A typical case of error message when trying to open a file is when you try to open a material preset and not the actual figure.
Hello, it's almost always ".duf" files, and here are the error messages, most of the time it's the first one.
https://imgur.com/a/QIlTTAD
https://imgur.com/a/yhudWin
The first one seems to be the "clicked on material preset" error, the second one I think might be because you have an addon for a clothes set, but not the base clothes set itself.
Is there any way to fix this?
Install the required content, if it isn't all one set, then make sure you load the model (usually tagged Wardrobe for a single item or Wearable for a set) and select the piece of clothing before you apply the materials preset.
First error message:
You downloaded and installed the textures from this:
https://www.renderosity.com/mod/freestuff/sleeveless-dress-styles/83875
They are for this free dress, which you have to download and install first:
https://www.renderosity.com/mod/freestuff/?item_id=80084
Then load the dress and afterwards use the materials.
