missing links?
I recently installed DAZ Central and it really messed things up for me.  I have since deleted it and using DIM I uninstalled all of my content.  Now when I install resourses through DIM, on some files there is no link to DS.  When I try load a charachter, I see the thumbnail image but when I load it I get a message that say the .duf file does not exist.  When I right click on the file and select browse to file, the files are actually there where they are supposed to be. Why does DS not know that?
  • Richard HaseltineRichard Haseltine Posts: 111,779
    That sounds as if your non-default paths have been set back to the defaults by Daz Central. Check them in Content Directory Manager - Edit>Preferences>Content tab.
  • donwaedonwae Posts: 5
    Thank you Richard.  You are a genious!  Once I changed those settings everything is working as it should.  Thanks again
