Setting up render node in Daz3a
I need some help setting up another computer to use as a render node. I searched the forums and the wiki but couldn't find any info on this. I am still using Daz 3a because the render node comp doesn't have enough power to run Daz 4.
What do I need on the node and how do I set it up?
  • fixmypcmikefixmypcmike Posts: 19,740
    The 3delight license included in DAZ Studio does not allow network rendering.
  • edited December 1969
    That's brilliant Daz!
    Thanks for the answer Mike. OK, I have Carrara 8 and it has a render node included. I can create my scenes, import them to C8 to render them, right? So, do you know how to set up the C8 node?
    You may want to ask in the Carrara forum.
    The licensing arrangement for DS is what allows you to get a free version of 3delight that can be used on more than 2 cores. Check the prices on 3delight.
