I can't copying material. Please how to
I can not use the material at the same time.
Image removed
Image removed
Image removed - please see https://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest
What is it you are trying to do? Does the producct you are using not come with presets? If you want to copy and paste surface settings you usually need to aply the base shader being used first.
