Alpha transparency
ewangrant1ewangrant1 Posts: 0
You guys are going to think I never search for answers but I do, just spent the last hour and a half reading threads following on from forum search. I know the information I seek will already be here, I just can't find it.
Created a new image, set as transparent. Added text and saved as .PNG. When I loaded in as a texture in Daz (on a plane) it looked perfect. Rendered and the transparency turned white. Checked transparency in image editor and it was set as 255, 255, 255, 1.
(Not sure what the 1 is for, guessing it is to do with on or off.)
Anyway, any quick answers? If I can get this sussed I can save a fortune in polygons. (Ooh, mentioning polygons, how do you check your scene for total poly counts again?)
TIA, and I'm sure I'll also thank you later too.
  • Richard HaseltineRichard Haseltine Posts: 112,275
    You can use the image's alpha channel in Shader Mixer, but if you are using the standard shaders it's best to have a separate opacity map - make a copy of your image, fill the painted areas with white and the background with black, then load that into Opacity Strength
  • ewangrant1ewangrant1 Posts: 0
    Perfect Richard, simple task for some clean cut letters. Headache ahead for a thousand leaves on a tree though.
  • JaderailJaderail Posts: 0
    LOL!! You want a headache. Model a tree with real leafs modeled on it. Tried it once, I never once thought of doing that again about half way down the first branch. I have Large respect for the PA's that do real modeled leafs now.
