Setting OpenGL render engine in a script
Hi, I'm new for DAZ. I found that the rendererList doesn't contain OpenGL. And I want to render a image by OpenGL and Iray.  Because of the lack of OpenGL, now I must save two Scene files, one for Iray and another for opengl. Is there a simple way to change Iray to OpenGL in a scene using script?
var oRenderMgr = App.getRenderMgr();var oRenderList = oRenderMgr.getRendererList()for(i=0;i<oRenderList.length;i++){	print(oRenderList[i].getName())}/* outputNVIDIA Iray3DelightScripted 3Delight*/
  • algovincianalgovincian Posts: 2,723
    You could Save As a Render Settings Preset, and then merge that preset into the scene via your script:
    var oContentMgr = App.getContentMgr();
    oContentMgr.openFile("your-render-settings-preset.duf", true);
    HTH.
    - Greg
  • XiaojingXiaojing Posts: 14
    Thank you!
    I found the code
    	// Set the render type to 'Basic OpenGL'; aka 'ScreenShot'	oRenderOptions.renderType = DzRenderOptions.ScreenShot;
    You helped me again!  I truly appreciate your timely help.
    HTH.
    - Greg
    Thank you for your answer! You provided another soultion for me.
