dForce Breasts, how do i do it?
So I'm trying to use https://www.daz3d.com/keicy-with-expressions-dforce-breasts-and-dforce-hair-for-genesis-8-female but i cant get the dForce Breast Add-on working.
It says "The dForce Breast Add-on acts just like an Implantable silicone prosthesis. It can collide with the object / character itself, shake with the character's movement, while keeping everything is natural transition.It’s very easy to use: select the character with dForce, click to load the add-on (it will fit to any G8F body shape automatically, without any extra options) and watch it simulate quickly!"
So i have G8 and load the addon make poses then hit simulate and nothing happends DAZ just comes up saying "No objects to simulate -add a dforce modifier or object to the scence.
What am i doing wrong? The disciption does say "select the character with dForce" does that mean i have to make G8  a dforce object or something? If so how?  I know i'm missing something here, what is it lol?
  • TheKDTheKD Posts: 2,711
    A new idea like that should really come with a PDF instructions.
  • LeanaLeana Posts: 12,994
    According to the readme there are several "materials" for the dForce breast solution, some for G8F and some for the breasts add-on. As dForce settings are surface settings they might be what applies the dForce parameters?
    Yeah i tried that, still nothing :(
    I have this product there are some presets (check the content library for this product) you must click on first so the figure has the dforce settings applied.
    The creator just started a FAQ thread, maybe ask them there?
    https://www.daz3d.com/forums/discussion/406611/keicy-dforce-breast-faq#latest
  • HamsterHamster Posts: 41
    Because your character is not a dynamic surface object.
    Load "HS 1Keicy with DFbreast "first, remove the keicy head and body shpae, then load your character shape and materials.This is the easiest way to work with other character.
    Yep thanks guys, I think it's working "simulating now". It seems you have to load "HS 1Keicy" character. I was trying to just add the dforce breasts to pre existing a character i made before.
