Bend Control for Genesis 8 Male(s) - Where is it?
Hi
Can anyone help me locate this in DAZ? Bought it a while ago but never bothered with it. Now I want to use it, but cant find it.
  • Zev0Zev0 Posts: 7,123
    Will be located here on your figure Pose Controls/Hip/Bend Control and here Pose Controls/Legs/Bend Control
  • gerterasmusgerterasmus Posts: 287
    Thanks, but... pictures? Sorry, blond.
    I can find glute control and G3 Bend control.
  • TheKDTheKD Posts: 2,711
    You mean you can't find it in your product library for download, or on your figure?
    It's downloaded and installed (and uninstalled and reinstalled ad infinitum). Can't find it in Smart Content or on figure
  • lilweeplilweep Posts: 2,864
    edited April 2020
    it will be under parameters, presumably, as they are morphs.
    Post edited by lilweep on
    And I can't find them in parameters.
    It's like it's not installed at all, but I know it is.
    edited April 2020
    It should be under pose controls > hip and pose controls > legs  in parameter section, if you have genesis 8 male root selected.
    Post edited by TheKD on
    Just uninstalled and reinstalled it.Still Nothing.
    @Zev0 Please help.
  • TykeyStudiosTykeyStudios Posts: 892
    edited April 2020
    I took a screen shot of my viewport. I'm assuming this is what you're referring to? It's not showing up under this category?
    546 x 1080 - 317K
    Post edited by TykeyStudios on
    @GlenWebb Yes. I don't have it there and can't find it.
  • nemesis10nemesis10 Posts: 4,009
    I see them in parameters > actor > pose controls in legs, hip and torso so I was going to have you use the  search function to look for bend control in the parameters first to see if you see the two controllers.  If not, deinstalled and reinstall.
  • HaruchaiHaruchai Posts: 2,040
    edited May 2020
    The only other thing I can think of is that the morphs are not loading because they are in the wrong place in the data folder. The morphs load from the data folder each time you launch a figure.
    On your computer navigate to the folder as indicated at the top of my picture (and below) and check they are there.
    My Library-data-DAZ 3D-Genesis 8-Male-Morphs-Zev0-Bend Control
    797 x 600 - 70K
    Post edited by Haruchai on
    Looked there, and no Zev0 folder there. I have Glute Control for G8M and Bend Control for G3M and I have no problem finding them.
    I've uninstalled it and reinstalled using DIM. If I uninstall it, it doesn't show up in DAZ under the install tab.
    edited May 2020
    IIRC when you uninstall in DIM and still have the zip available it should put the file in 'Ready To Install' not back into 'Ready To Download'. Do you have anything in your DIM 'Ready To Install' tab? If not look for it in 'Ready to Download'.
    Another solution would be to open the zip file and manually drag the data folder from the zip into your main My Library folder. This will make sure it is installing in the right place. Make sure to drag it into the main folder not inside the My Library-data folder or you will end with a nested data folder and it won't work.
    Note - Your zip will be named differently to mine, I rename all my zips so they appear alphabetically not in IM number order.
    1280 x 530 - 63K
  • RAMWolffRAMWolff Posts: 10,382
    Perhaps you can go to your product library here at DAZ3D, manually download the zip file, open it up and hand install it?  Might resolve this faster for you!
