Program always uses "Save As"
I receintly ran into a problem after re-installing DS.  Whenever I have a scene and go to save it the program forces me to enter the file name even if I have already saved the file.  I am using the "save" file option not the "save as" option.
  • LeanaLeana Posts: 13,711
    IIRC it will do that if you didn't enter your "author name" (or something like that, I don't remember exactly how it's called) in DS parameters.
    In order to avoid overwriting scene files from products DS will allow a "simple save" only if the author name for the scene matches yours, otherwise you need to save as a new scene. If you haven't defined your author name it will consider it as "not matching" by default.
