Invisible morphs? Solved
nabob21nabob21 Posts: 1,058
I have recently found the morphs under the Parameters tab and not the Shaping tab. Thanks to anyone who may have been looking into this.
nabob21
Post edited by nabob21 on
  • Richard HaseltineRichard Haseltine Posts: 111,390
    It's always a good idea to check the Parameters pane as it shows everything. Presumably if you click the gear icon on the slider and open Parameter Settings the Type is not set to Modifier/Shape, ideally the creator should fix that.
