Flip hair?
Is it possible to flip hair so that the part is on the opposite side?
  • gitika1gitika1 Posts: 948
    I own it, but haven't had the opportunity to use it.  I believe  https://www.daz3d.com/mirror-geometry is supposed to do what you are asking.
  • felisfelis Posts: 6,553
    If you're not fitting it, but just parentinting it you should be able to scale the hair with -100% on the X-axis.
    nifty trick, hadn't ever considered that.
    Did a few quick tests and the results were acceptable. Even when i had hair 'fitted to' a figure, g8f specifically.
    Only had a couple of the tests where i got a bit of weirdness, mostly bulges in the sides of shorter hair, but over all, a lot faster than the mirror script.
