Cloth obj import?
Hello everyone,
I'm new to DAZ and I would have liked to know if it is possible to import in Daz a clothe in obj format (only mesh) that was made by another software?
If so, how?
Thank you very much because it is very important to me...yes
  • LeanaLeana Posts: 13,614
    Yes, it's possible, that's how clothes are created usually. There's an "import" feature in the menu.
    Once imported you can transform it into conforming clothing using the transfer utility, then save it as a figure asset.
  • Richard HaseltineRichard Haseltine Posts: 111,792
    You may need to experiment with the options for the importer - if it was modelled around a Daz figure you can try the 100% option, otherwise if you know what application was used to model try selecting its preset in the middle of the dialogue (this may work for content modelled around a Daz figure, if it was exported to be actual size in the modeller). If the imported item is too big, too small, or oriented the wrong way you will need to try other settings.
