Ultrascene problem
Hello guys
I'm new in Daz 3D and need some help.
I have figured out basics of the program, modelling etc.
However, I have this problem of scripts not being loaded. Sometimes it helps to reset database in Content Database Maintenance, but for some scripts it doesn't help.
For example scripts in UltraScene can't be fixed with this approach - when clicking the script it says "An error occured while reading the file"
Here is what it says in the log file:
2020-04-07 18:58:58.413 Beginning Install of "UltraScenery - Realistic Landscape System"
2020-04-07 18:59:05.321 "UltraScenery - Realistic Landscape System": Install Succeeded.
2020-04-07 18:59:05.322 "UltraScenery - Realistic Landscape System": Install Succeeded.
2020-04-07 18:59:05.330 "UltraScenery - Realistic Landscape System": Install Succeeded.
2020-04-07 18:59:12.337 WARNING: QFont::setPixelSize: Pixel size <= 0 (0)
2020-04-07 19:00:26.964 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2020-04-07 19:01:07.888 Loading script: D:/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_67835/environments/landscapes/ultrascenery/resources/scriptcomponents/hf_app.ultrascenery.ui.dse
2020-04-07 19:01:07.892 WARNING: Script Error: Line 3
2020-04-07 19:01:07.893 WARNING: ReferenceError: Can't find variable: hf_app
2020-04-07 19:01:07.893 WARNING: Stack Trace:
<anonymous>()@D:/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_67835/environments/landscapes/ultrascenery/resources/scriptcomponents/hf_app.ultrascenery.ui.dse:3
2020-04-07 19:01:07.894 Error in script execution: D:/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_67835/environments/landscapes/ultrascenery/resources/scriptcomponents/hf_app.ultrascenery.ui.dse
2020-04-07 19:02:12.184 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
I run Daz studio 4.12 Pro
Any help with this will be highly appreciated as it is really frustrating when actually figuring out how the program works, but then getting these random error messages.
It should be noted that materials and props are loading in UltraScene, but the scripts are a problem.
Thanks in advance!
UltraScenery is not currently written to work with Connect installs (installs through Daz Studio itself) - try uninstalling that and installing it trhough Install Manager. The author has a thread here https://www.daz3d.com/forums/discussion/380431/ultrascenery-commercial-released#latest
