Cannot save my custom morphs
Hi there
Im using the genesis 8 starter essentials, went to brush, created a morph. Brought it back, everything works wonderfully.
Except when I go to file/save as/support asset/morph asset
I add my morph to the checkmark list(only thing I check the x) ,but for the life of me, it never saves anything. i tried saving in the 3 different paths it allows me to, but the morphs don't show up in neither of them, and in the smart content search doesn't show up either.
what am I doing wrong?
thanks in advance
  • Morphs are not going to show up in the Smart Content ... they show up on the Parameters and/or Shaping Panes.
    ? what these 3 different paths are you are referring to. They would have saved to be seen exactly where they were planted in the first place.
    The data files would be in the data folder, subfolder for the figure [normally under DAZ 3D] under Morphs, base, your handle. You can only have one working morph with the same name so if you have saved it to 3 different places, 2 of them must be deleted from the data folder.
    If you forgot where you parked them: in the file in the data folder search for "group" ... and there will be where it is located when you open D/S to use it.
    {the figure has to be loaded and selected in the scene in order for any of its shapes and morphs to be seen}
  • ItsaMeItsaMe Posts: 42
    yeah i cannot find them in the folders...no where ...seems like a bug or something
    I was able to find the file in my dropbox(the third path it gave me a choice of) but now I'm unsure with what to do with this file or where to put it
  • Richard HaseltineRichard Haseltine Posts: 111,389
    The files are not meant to be visible inside DS, they go in the hidden Data folder, in specific sub-folders. Are they actually loading onto the figure? If so theya re in he right place (other than which cntent directory they are in, perhaps - you can set that at the top of the options dialogue  when saving the morph asset).
