missing my default shaders
Hey i had to do a master reset on my computer an in reloading the Daz3d program the install manager (or me) has managed to leave out the default or basics material shaders. I use the emisive shader a lot and i don't have it anymore. Does anyone know where i can pick this up? thanks in advance.
  • fastbike1fastbike1 Posts: 4,081
    Should be Iray Essentials IIRC. Look in your Products on the DAZ site.
  • NorthOf45NorthOf45 Posts: 5,721
    Default Resources for DAZ Studio 4.9+. You won't find it searching in your Product Library, it's part of the DAZ Studio 4.x Pro bundle.
  • First, thank you somuch for the replies.
    Instead of running through the content library to find it go through smart content? im a bit unclear because i had the seporate folders in content libary before and it was easily accessable. IT would be awesome if it was still there. second to this then is there a possibility to migrate it to the content library? it's just how i've learnt and my work flow.
    The Content Library only shows installed content. If you install with Connect, you should see it in the Products, Available tab. If you use DIM, type the name (or enough of it) in the filter box to see where it shows up.
