atmospherics? Volume lights? Fog?
Hi all
i was wondering if there is anyway to achieve this in dazStudio4 pro? i looked in the light settings, render settings and even camera settings, but i am not able to find any settings to turn on any kind of volumetrics. I hope you can help, so i can give more depth to my images.
I'm using iray
thank you
  • mavantemavante Posts: 734
    I recommend you start here:
    Plane Easy Atmospheres
    AtmoCam for Iray
    Atmocam2
  • NorthOf45NorthOf45 Posts: 5,896
    Volumetrics can done natively with Iray shaders, but you have to set them up manually. Some products have demo scenes that have the effects already set up. Both Atmocam products do most of the work for you and make it easier to work with. There is also Terradome 3's atmosphere shaders, part of a complete terrain system. Most of the other atmospheric props are billboard-based, often using multiple layers to get that graduated effect, but an order of magnitude or two faster than real volumetric effects. 3Delight has equivalents, like the uberVolume built-in shader, and billboard-style fog and smoke props.
  • ItsaMeItsaMe Posts: 42
    Thank you
  • A good starting point is here
    thanks!
