Geometry editor issue
I've used the geometry editor a few times. I assumed that it was modifying the asset *in my render* and no more. But I saw today that it was modifying the asset in my library.
I wanted to make a shoe dissapear (but only one, not the pair), so I created a surface with the geometry editor, and gave it an opacity of 0% . But when I tried to load again this pair of shoes, I saw that the one I had modified didn't have any texture anymore. The asset itself has apparently been permanently modified.
How do I modify the geometry of an item *only for a specific render* without it modifying the asset itself? Thanks in advance, I hope that my question is clear.
  • felisfelis Posts: 6,665
    If you save the modified version you must save it with a different name. If you haven't saved it at all, I can't see how it can have changed the original.
  • odasteinodastein Posts: 606
    edited March 2020
    I didn't save it. I loaded the shoes, edited one of them. Once done I loaded the same pair of shoes on another figure and they came as you can see in the attachment. I tried to add the material to this second pair, but it had no effect, they stayed this way.
    Edited to add : though I didn't save the shoes, I might (I don't know) have saved *the scene* .
    620 x 459 - 228K
    Post edited by odastein on
  • Richard HaseltineRichard Haseltine Posts: 112,142
    Is this in the same scene? If you want to have the basic and the modified item both in the scene then you need to save it as a new asset (File>Save As>Support Assets>Figure/Prop Asset), as DS will keep oly one copy of a given asset in memory at once and currently that's the version you modified.
    edited March 2020
    Yes, it's the same scene. OK, thank you, it explains it all.
    I was afraid that I had permanently modified every asset for which I had used the geometry editor in the past.
