Flame Rendering Black
dc19dcdc19dc Posts: 22
I'm not sure what I'm missing, maybe a light not being placed somewhere. As you can see in the screenshots when I try to render the image the flame turns black.
653 x 411 - 38K
1097 x 458 - 97K
  • fixmypcmikefixmypcmike Posts: 19,744
    What file format is the flame in, and what shader does it use?
  • Richard HaseltineRichard Haseltine Posts: 112,275
    You may need to set the Diffuse colour to white - in Poser ambient is independent, and I expect that is what they are using, but in DS the ambient is multiplied with the diffuse, which is more realistic but can break using it for glows if the diffuse colour is not set correctly.
  • dc19dcdc19dc Posts: 22
    I hope this helps. Sorry for the late reply, I've been out of town with no wifi.
    276 x 202 - 29K
  • JaderailJaderail Posts: 0
    It is still just a Surfaces setting in DAZ Studio, something in the Poser materials is setting it to Black. As Suggested check the Flame texture in the Surfaces Tab and look at the Ambient and Diffuse channels. They are often set up wrong for DAZ Studio renders.
    That will be the ambient issue I mentioned then. I think there should be a DAZ Studio version of the set, but if there isn't use Tools>Surface Selection to click on the flame, then open the Surfaces pane (Window>Panes(Tabs)>Surface) and make sure that the Diffuse colour is set to White - if not, click it's colour bar and pick white in the dialogue.
    So I need to diffuse the figure or pose, or both files in Poser, I'm wayyy more comfortable in DAZ working. I bought the Fantasy and Sci-Fi Effects because it says it's compatible with DAZ.
    This is Done in DAZ Studio in the Surfaces TAB. Not in Poser. This is a Different model but shows what to look in... Check the Diffuse Channel on the Fire prop...
    504 x 671 - 54K
    Ok I was able to track down where the diffuse color area using your steps and I set it to white...and it FIX IT!!! thank you!!!!
    It looks like you're using the Poser version of the product -- there are DS mats in "My Library\Shaders\B9999_FX" (if your content library is named My Library).
