Missing Files - Despite Install
AdvintAdvint Posts: 23
Daz studio is showing missing files regarding a few things, but specifically the default resources for Daz 4.9+ for me. I've tried reimporting metadata and searching directories for new files. However I'm at a loss. The content directories are set up correctly in daz studio, as well almost all the content I have isn't having this issue.
I did reinstall my entire directory not too long ago, and likely didn't notice this issue until now. Though I'm not sure if this is the cause.
Post edited by Advint on
  • Richard HaseltineRichard Haseltine Posts: 110,563
    How did you install?
  • AdvintAdvint Posts: 23
    I used Daz Install Manager to install. However, when I sort of moved libraries around I installed  everything to a different drive. Which is why I think I am having this issue. I believe it's looking in the wrong place for the content, but I don't know how to correct this. Sorry, I could have said as much earlier.
    DS uses relative pahs - the location within the content directory - for its database so the most likely issue is that the files are not in the correct place in the content directory (or conversely that the wrong folder iss et as the content directory). The content directory is the ne that holds the Data and Runtime folders, they should not be in a sub-folder of the content directory and should not be selected as content directories themselves.
    edited March 2020
    I checked the paths that Install manager was pointing to for the products, and am just going to reinstall them to those paths. I believed I had already reinstalled the default resources to a new path. However I expect this to resolve my issue.
    Edit:
    This has been resolved, thank you.
