Error Creating G3 Morph
I get the error message Geometry did not match, failed to create morph when using morph loader pro to create a morph for genesis 3. The morph is based on a genesis 8 Character. The eyelashes are removed, resolution set to base and sub-d to 0 before I export the genesis 8 character as an obj. Any other suggestions?
  • Export settings are ?
    Importing/exporting from which modeler?
  • Export settings
    517 x 689 - 53K
  • LeanaLeana Posts: 13,711
    You're trying to create a G3 morph from a G8 mesh using morph loader? That won't work, morph loader can only create a morph from a mesh based on the same figure.
  • bca_media15bca_media15 Posts: 7
    edited March 2020
    I used Transfer utility and it worked. Thank You very much.
    Post edited by bca_media15 on
  • I used Transfer utility and it worked. Thank You very much.
    Well we all like to learn new things. How did you make a morph for G3 out of G8 using the transfer utility?
