Problem with lip syncing
I am using DAZ 3D 32bit so I can use the lip sync capability. Is there a setting somewhere that can adjust the strength of the morphs being used? It almost looks like they are going at about 110% strength. I am using a Genesis 3 config file with a Genesis 8 character. I then export the animation out to FBX and import into Cinema 4D. The strength of the morphs are greatly increased during this process as well.
I am willing to try just about anything to get this to work. I can't use a Genesis 3 character as I am using the Face Transfer utility which only uses Genesis 8 characters. Does anyone know if there is a Genesis 8 DMC file for lip syncing or how I could modify the Genesis 3 file to work with Genesis 8.
Thanks in advance... Al
Genesis 8 mimic files [dmc] are in our Product Library, come with the Genesis 8 Starter Essentials.
Check your exported morphs . They probably are doubled up. Click on C4D pose morph tag.
You might have head_eCTRLv* visemes, along with Genesis8Female.eCTRLv* visemes
You can set FBX export rules to ignore one set when exporting, or delete one set of entries in the pose morph tag if you don't want to re-export
