Daz Timeline. How to hide unused nodes/parameters?
I want to animate the smile morph and other properties, which aren't in this sub-menu. I have to scroll a lot, because there are all these elements, that I am not using. Is there a way to only display elements in the timeline, that I am actually using?
Thanks for answering my friends.
  • wolf359wolf359 Posts: 3,955
    No.
  • wolf359 said:
    No.
    Short and concise, thanks :)
  • Chris CoxChris Cox Posts: 54
    edited March 2020
    If you don't need the the parameters visible on the Parameters Tab you can hide them there, It's easiest to do this in Edit Mode where you can select multiple parameters and make them hidden all at once.
    You may also need to make the timeline refresh the list to have the hidden items not display.
    Post edited by Chris Cox on
  • IvyIvy Posts: 7,165
    edited March 2020
    If you click the timeline tool bar found on the little tab in the up right hand corner of the timeline and make sure the advanced view unchecked. it should hide all properties accept for the characters & props loaded.
    Someone ask a question that was just reversed to yours  ,so if you follow these directions https://www.daz3d.com/forums/discussion/392736/need-a-little-timeline-help
     and just go backwards from these steps  and make sure the shut the advance view is off it will hide the graph & advanced keyframe editors so all you see is the default timeline with no properties edit  nodes
    Post edited by Ivy on
    right i forgot that way too.
