Geometry editing overwrote
I changed a surface on dog8 with the geometry editor
I never saved my scene even but it has overwritten my original
how is this even possibe?
I will reinstall it with DIM I guess to fix but this is baffling
  • Richard HaseltineRichard Haseltine Posts: 111,430
    Did you use File>Save As>Support Assets>Save Modified Assets perhaps?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,560
    I saved a pose thats all I never even saved it as a scene
    the pose was just meant to keep its position after I deleted it actually
    reinstalling fixed it but I might be less inclined to mess with the geometry editor if this happens
    I wouldn't expect it to happen, assuming the clean figure was loaded into an empty scene, so I'm not sure what happened for you.
  • I think it has to be something that happened during that save. I have used the geometry editor brush several times to make temporary shading domains, fresh loads were always back to normal.
    yes I believe it was the pose save myself
    which is disturbing as the reason I saved the pose was actually so I could delete it and load the unmodified figure
