Luminosity problem
Hello.
I have been experiencing this problem for some time now. But that hadn't been a problem in the past ... Today, it becomes annoying to have to cancel a twentieth image for a problem of brightness.
As if our sight released a very powerful luminous spot ... Like the gorgon in image 1.
How do you fix this please?
  • SimonJMSimonJM Posts: 6,100
    In Daz Studio? Iray or 3Delight?  Assuming Iray in Daz Studio, what I tend to do (and others will have other just as worthy, or better, ways ..) is make sure the Camera headlamp is off, select Iray for previw moe and let it start building the image so I can get a general overview of the brightness, etc.  Depending on the lighting used I will either adjust the output of mesh lights or adjust the ISO setting in Iray properties.
  • maki2859maki2859 Posts: 45
    So it's called the headlamp. Indeed it was activated. I had to search to find the option.
    I only use Iray very rarely because of the slowdowns that my computer experiences when I use it.
    The problem of light in the foreground is solved. Thank you very sincerely for this help. Sorry if my questions are stupid or simple. ^^ '
    Not at all, no-one knows everything and Daz Studio is quite a complex beast!
