Why would iRay preview render be popping up when I have the viewport on texture view?
Hi all!
Why would the iray render processing box pop up when I am just working with the texture mode (and not even looking at anything textured in the viewport)?
Thoughts?
3113 x 1885 - 1M
  • mclaughmclaugh Posts: 221
    Note that you have the spot render tool selected. Does this happen if you switch to a different tool?
    Have you verified that there isn't an iRay render running in a window behind the main window (or a minimized window)?
  • SevrinSevrin Posts: 6,314
    If your render mode (Render Settings) is Iray, it doesn't matter what settings your preview (Draw Settings) is set to when you render.  They're two separate settings.
