Products not visable
I downloded some Kitbash3D products and when I open them I cannot see the product in the workspace. When I click on it in the scene tab and hoover over it I can see it highlighted but once I move the mouse curser then I cant see them again. Any suggestions on what the problem may be?
  • Richard HaseltineRichard Haseltine Posts: 110,544
    Select the item, go to the Surfaces pane and in the Editor tab select it from the list there, then set the Opacity or Cutout Opacity to 100%/white.
  • Jason GalterioJason Galterio Posts: 2,562
    Subscribing because I had a similar problem with some bought items.
    I was led to believe that it was because the models were missing an attribute. Like they needed to be "inflated"...  but I wasn't able to find a way to fix it.
  • Awesomeness! Thank you so much! Worked like a charm!
