What is the proper way to show G8F in a screenshot so the image doesn't get removed? (solved)
FlortaleFlortale Posts: 611
edited March 2020 in The Commons
edit: i found the rules here: https://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest
I need to ask people how to fix inbetween the leg and hip area when G8F's legs are bent.  It would be easier to show a screenshot of the problem area, but I'm not sure how to show G8F without getting the image removed. What are the forum guidelines for showing G8F in a screenshot to point out body problem areas and get technical feedback?
Post edited by Flortale on
  • akmerlowakmerlow Posts: 1,124
    Replace texture with gray material, i think?
  • FlortaleFlortale Posts: 611
    I actually replaced the skin texture with a cloth material.
    I found the stickied post that talks about the issue: https://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest
    edited March 2020
    Which says that
    if it's essentially skin-coloured
    then you hide with objects, while if it not (like, non-skin material), then it's ok, like those pictures from daz store products sometimes
    Right?
    In worst case, how about wireframe?
    edit:
    Ah, you mean you found your solution, ok :)
    Post edited by akmerlow on
  • MimicMollyMimicMolly Posts: 2,371
    Gray texture or a cloth shader would work, or the wire shaded view you tried in your post.
    Showing the model in a bikini or underwear is acceptable too, at the minimum, if you want to post a pic with your model's skin details. Think of how the characters for sale here at the shop are dressed up like.
