breasts
When breasts are pushed against a surface.. they flatten (a bit) ... I see examples with DAZ3D where that is done with G8 ladies..
But how to do it ?  I do have Breastcorntrol for G8, and it seems to be possible with that.. but i can not find out how to activate the morph
  • Since you have Breast Control Genesis 8 Female(s), what you need to do is select the figure, then on the Posing tab drill down to Chest > Breast Control, and you'll see all the posing morphs there. The one you need is called something like "impact front".
  • efron_24efron_24 Posts: 478
    thanks ... I am going to search for it
  • ParadigmParadigm Posts: 425
    You can also apply a smoothing modifier to the figure and have the surface the collision target. Reduce either the collison iterations or smoothing interations to 1 or 2 and you can get some pretty good results. I do it frequently for a little squish when people are sitting on a hard surface (or use it on a soft surface for a little indent). The trick really is putting one of them to 1 or 2 so the indent isnt huge.
    that is way to technical for me...  smoothing modifier ?  iterations... ?  That is a bit too much.. but thanks
    It worked.. thanks
  • mindsongmindsong Posts: 1,796
    In previous figure generations, products have been made that enable 'squish' morphs that specifically address this need. These usually include butt squishing morphs as well for sitting figures, etc.
    I don't know if any PAs have released such a package for G8F, but others in the forums might be able to recommend options if they exist.
    --ms
