Weight Map Conversion problems
I have a number of older objects that are in .pp2 and .cr2 format that I want to convert to .duf. for the most part I have no problems, but ever now and again an item comes up that needs to be converted to weight mapping to save it to .duf. PROBLEM: the text box says to goto edit>figure>rigging>convert to weightmapping. if you follow that in 4.12pro you can only get ase far as edit>figure>? there is no option for rigging offered in this version. What do I need to do to convert these objects/figures to weight mapped?
.pp2s are not rigged and therefore do not require conversion. Simply save them as prop files ;-)
